Just did my swap and everything went pretty smooth. when I was transfering over the eng harness the speed sensor pigtail did not clip into the b16 vss. I popped the wire pins and tried putting them into the old clip. They went in but I dont know if the went in properly because I have no speedo. My ? is this will my vss transfer over from the d series to the b-series? Does anyone know if I can get just the pigtail connector that plugs onto the sensor from honda? My foot seems to be a little heavier without a speedo, so help is greatly appreciated.
on the top side of the tranny, you should be able to get to it just by taking your intake off. it's one connector and 4 screws i think.
I had the change the same exact thing from going with the cable tranny to the hydrolic unit. Got a VSS from a GSR odb1
