Howdy, Y'all. And thanks for taking the time to read my post.
I've got a '91 Prelude 2.0 si. The speedometer and the odometer will stop working at random, then start up again -- at random. Read similar posts, but mine may be a bit different -- or maybe i'm just confused.
assumed it had something to do with the vehicle speed sensor (not the power steering speed sensor). tested it with a 12-volt test lite. no power going to the sensor, regardless of whether the car is running or just has accessory power. is this supposed to be this way?
but, after reading some of the posts here where folks had similar problems, began to wonder if it had anything to do with my power steering speed sensor (as this seems to be the sensor that folks were referring to as the vehicle speed sensor). My power steering had a major leak -- as in running damn near bone dry -- and i wondered if the fact that the P. S. speed sensor wasn't getting any fluid would impact the speedometer. i've since fixed the leak, but haven't been able to test the car yet, as it's being repaired. driving it slowly back and forth in my driveway didn't cause the needle to move, though.
any thoughts would be appreciated.
:tpp:
:tpp:
