Speedometer question
Discussion in 'HYBRID -> ED-EF / DA' started by boostin4fun, Feb 4, 2007.
  1. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    Im in the process of swapping a ls/vtec into a 88 crx dx. Im using a newer b16 hydrolic transmission out of a 2000 si. I was wondering what to do for the speedometer cable. The hydrolic transmission uses a electronic VSS. What parts do i need to fix this. I will be converting this to mpfi and using a obd1 jumper harness. So will this computer still need the electronic VSS? Any help would be apprecitated. Thanks.:(
  2. boostin4fun
    Omaha
    Anyone else have any thoughts on this?? I know there has to be some 88 swapped crxs out there with the newer transmission im using.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    :withstupid:
  4. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    x3
