Spindels On 91 Hatch
Discussion in 'HYBRID -> EG-EK / DC' started by sooboss, Feb 28, 2003.
  1. sooboss
    sooboss Senior Member
    I am currently doing a swap. Putting in a B16a. my question is will the dx civic hatch spindels work on this swap. The car was a 5 speed before the swap. Axles are taken care of..
  2. sooboss
    does any one know...
  3. EFtypeR
    EFtypeR Junior Member
    I just did a 90 dx hatch. Kept the spindles, removed the spacer. Stock 87-89 Teg axel on drivers side, stock 90-93 Teg axel for the pass. There is no dust seal, by the way, unless you get the axels with ABS. Don't get the ABS axels, and your good. Hope this helps.
  4. sooboss
    wow so they can be kept. if it were a 4 speed then i would have to change them out... thanks
  5. Civic_88ls
    Civic_88ls Senior Member
    everett, wasington
    I put a b18a in my car and found it way easier to just put on the 90-93 integra spindles. they bolted up and i brake faster too. The axles fit right into there.
