spindle swap
Discussion in 'HYBRID -> ED-EF / DA' started by geedog66, Aug 16, 2009.
  1. geedog66
    geedog66 New Member
    i have a 91 civic si and i have a complete donor 91 integra i wanted to know if can use the upper control arms on my si to make the integra spindles work cuz i know that the spindle wont work by them selves
  2. 78civic
    78civic Junior Member
    NW MS, Y'all
    I just did a 4dr 90 teg/civic rear swap that turned out ok.. The only part that I saw that was different was the lower control arm was straight for the teg and bent for the civic. I think the teg is slightly longer also. BUT the swaybar wont work from the teg.
    E
  3. geedog66
    geedog66 New Member
    i was messing with it last night and i found out that the upper control arm is a hair wider than the 91 civic si control arms im tempted to drill out the bolt holes on the car to make it work
  4. 78civic
    NW MS, Y'all
    I wouldn't go that far.. If it won't bolt up it could be dangerous.
    I tightened up the arms before I lowered it to the ground and it looked jacked up. I was late leaving for work and couldn't change it so i had to drive it like that..
    I think i tore some rubber mounts doing that.
    E
  5. D16SiHatch
    D16SiHatch New Member
    why are you trying to put the teg spindles on your si?
  6. geedog66
    geedog66 New Member
    im trying to put it on a 91 dx to upgrade to the bigger brake set up... plus im almost positive that the dx and si carry the same brake setup.. im test fittin the spindle setup on my si hatch because i get my dx hatch friday...
  7. efhondakid
    Akron-Canton, Ohio
    Four door EF EX front spindles swap right on and are bigger brakes than the DX, But no matter what route you go, DA, Si, or the fodo spindle you will have to use Si axles.
  8. geedog66
    geedog66 New Member
    well i got my hatch friday and went to town on strippin the car out as well as the suspension i was able to make the integra spindle work without cutting or drilling... all i did was take that bar that runs from side to side on the back side of the upper control arm and bolted the upper control arm where it belongs and it fit like stock.. so now ill be running integra brakes all the way around on my swaped dx hatch
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ?im confused
  10. geedog66
    geedog66 New Member
    what are u confused about?
  11. INJEN78
    INJEN78 HS LEGEND
    OHIO
    what model do you have an si or a dx?
  12. geedog66
    geedog66 New Member
    i have both i was goin to use my si hatch at first but since i basically got the dx hatch for free and it isnt rusting away like my si im using it... i have the susp already installed plus my complete front chassis harness and dash from my si... next project is getting the motor mounts to line up
