spline count on spindles
Discussion in 'Wheels / Suspension / Tires / Brakes' started by Dark91zc, Jan 13, 2006.
  1. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    what is the spline count difference from a base model 91 crx to a 91 standard civic hatch
    i was told that the standard civic hatch and the crx hf share the same spline count.
    thanks
  2. swanny
    swanny Senior Member
    buck teeth and government checks, PA
  3. Dark91zc
    Corona,CA
    Not Tranny splines Spindles hubs where the axle bolts too.
  4. swanny
    I think the Si, Dx, and LX use the 26 spline outer joint. The HF and STD use the smaller 23 spline outer joint.
  5. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    yes the hf and std have the same spline count. I'm unsure what the exact number is however.
  6. Dark91zc
    Corona,CA
    thanks i found out last night i just got a set of dx spindles for free and alxes :)
