Spring Rate
Discussion in 'Wheels / Suspension / Tires / Brakes' started by smurf bnms, Apr 4, 2003.
  1. smurf bnms
    smurf bnms Junior Member
    Tampa, FL
    I'm am about to purchase some coil-over's in pretty much any spring rate I want. I was just wondering if anyone has some spring rates that they really like for autocrossing and/or road racing. I have progressive rate springs now that work alright, but I am looking for a linear fixed rated spring for more consistent handling. I have an EG civic that will have a B-series in it soon. I have heard that some people running 450F/600R all the way up to 550F/1000R. Any comments/suggestions would be helpful, thanks.
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    I will be running 6K front/8K rear next week. One major question is do you want to daily drive on this too? My spring rates are almost the max you can go on street, higher then that and you might as well weld the axles to the chassis
  3. smurf bnms
    Tampa, FL
    I dont care at all about ride quality first off. I dont drive the car daily..just to and from events and occasionally around town. Will an 18k rear spring cause the upper shock(strut?) mount to break or any other suspension component for that matter to break? Welding it is a little extreme but I get your point.
  4. Baker
    Baker Senior Member
    Schaumburg, IL
    holy shit! 6000/8000 thats insane
  5. smurf bnms
    Tampa, FL
    No no...he meant 6kg/mm and 8kg/mm. It works out to be around 350lb/in and 450lb/in, or something like that.
  6. pissedoffsol
    my HA's are 8kg Front and 6kg rear. (447/335)
    i'd like to go to a 550/650 later this year. I'm beginning to dislike the Tein's. Bill's rust froze on. mine are getting there. junk shit.
    JIC > Tein
    I shouldda waited
  7. asmallsol
    b, what did you use to lubricate/prevent rust with. So far I have heard like 20 diffrent products to use. Dielectric grease, lithium grease, wd40, anti sezie. What is the best to use?
  8. Baker
    Baker Senior Member
    Schaumburg, IL
    I think I'm going to run 400/300
  9. 98integrals
    98integrals Senior Member
    Kzoo
    im gonna be using H&R race, 460/350 2"/1.75"
    for the money ($165 from tirerack.com) they are a great deal. you just dont have adjustable ride height with them.
  10. phunky.buddha
    Dallas / Fort Worth, TX
    :werd:
    Me still getting JICs. :)
  11. pissedoffsol
    it doesn't matter colin. spraying them just attracts sand to stick to them.
    i'm selling my teins very soon i think
  12. CRX-YEM
    Wallingford, CT
    why not get dust covers ??? like stock shocks have ??
    and I'm assuming when people say for example 8kg Front and 6kg rear. (447/335) the 447/335 are lbs/in
  13. pissedoffsol
    dust covers dont fit
    and yes you are right dennis on the lbs/in
  14. B16
    B16 Super Moderator VIP
    yay area, CA
    i dunno, B you should talk to dan over at rcrew about JIC's, he hates them, they are supposed to be junk. the HA's were the only ones with the rust problem, you shoulda got SS's ;)
