i read up somewhere that the h22a engine swap into an 88-91 civic needs integra springs in the front.....my question is would it be possible to put aftermarket springs or do need the stock springs. thx
the only reason why they suggest that is to compensate the weight of the h22 motor, you can put in aftermarket springs. just make sure that the spring rate is good for the weight you'll be putting up front. I've heard that some people even put accord springs into the 92-95 civic struts.
