well ive decided to rebuild what i have.
max bore TB $100
extrude hone IM $429 might not do it
bought
82mm CTR nippon pistons $159
OEM honda
1 x COVER ASSY., R. SIDE $53.43
1 x PUMP ASSY., OIL $93.82
1 x WATER PUMP (YAMADA) $75.80
1 x TENSIONER, TIMING BELT $54.21
1 x GASKET SET, HEAD COVER $38.02
1 x RUBBER, SEAL (LOWER) $20.61
1 x SEAL B, ENGINE MOUNTING BRACKET RUBBER $2.75
1 x COVER, TIMING BELT MIDDLE $17.53
1 x COVER, TIMING BELT BACK $20.25
1 x SEAL A, ENGINE MOUNTING BRACKET RUBBER $3.61
1 x RUBBER, BACK SEAL $21.53
1 x SWITCH, OIL PRESSURE (TEC) $6.09
1 x GASKET, OIL PAN $19.83
1 x O-RING (26.2X2.4) (NOK)
$1.33 1 x GASKET, OIL STRAINER $1.51
6 x BOLT A, TIMING BELT COVER $16.02
2 x BOLT, TIMING BELT COVER $5.96
Sub-Total: $452.30 UPS and FedEx (Ground): $13.10 Handling Fee: $4.95 Discount Coupons:honda-tech10:
$10.00 Total:
$460.35
https://www.hondapartsdeals.com
$420+/- for the machine work plus final assembly
Check this ebay store out they got everything you need in da kits.. heres a b16b CTR Full engine gasket set head and block, with pistons and race bearings.. this would be the N/A Setup if you decide not to run boost $259 FREE SHIPPING
eBay Motors: JDM B16B Civic Type R Integra Pistons Rings Bearings (item 180246456919 end time Jun-23-08 15:17:07 PDT)
eBay Motors: B16B Civic Type R Pistons Rings Race Bearings Integra (item 160244022618 end time Jun-23-08 15:17:07 PDT)
$295
Heres a Low compression setup from them.. they have oil pump and water pump kits also.. But these kits are an awesome deal considering its every gasket under the hood, and pistons wrist pins and race bearings!
eBay Motors: Low Compression Pistons Kit Civic Si Type R B16A Vtec (item 180255753640 end time Jun-26-08 06:46:59 PDT)
$249, but not a full gasket set in the deal.. Flip through what they have.. I'm probally getting that b16b kit for my ls block and b16a head.. They tell you the compression ration for the swap your doing, for wich ever head block / piston setup your getting.. All free shipping.. Kiiilllllaa
-Kevin
