Squeaky lower contol arms..wtf?
Discussion in 'Civic and CRX - EF' started by HATCHET_HONDA, Jul 20, 2008.
  1. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    recently i installed some new megan LCA'S on my 90 ef hatch....buut the damn things squeak like a sonofabitch!! ive greased them , tried wd 40, everything.. nothing seems to work.. any suggestions?
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    WD40 is not a lube!!!
    Try lithium grease. If that does not work, try a lot of lithium grease. Also, this should be in the EF forum.
  3. HATCHET_HONDA
    hobart, indiana
    is the spray any good?or just get a tube of it ans smear a butt load on the bushings.. and yea thanks i just noticed i posted in the wrong forum..its 2am..oops
  4. K2e2vin
    Raleigh, NC
    I've used the spray and it works well, but I'd recommend the grease in a tub/tube because it's thicker
  5. Ethan
    Ethan Well-Known Member
    I hate WD-40!
  6. phunky.buddha
    Dallas / Fort Worth, TX
    :moved:
    Check to make sure that the bushings aren't broken in some way. Lots of people have had problems with the bushings in the Megan LCAs, and quite a few people also replaced the bushings with new polyurethane ones.
  7. HATCHET_HONDA
    hobart, indiana
    ya know that mite be the problem..theyre not broken but theyre quite stiff and like plastic feeling to me...where could i pick up new bushings?
  8. phunky.buddha
    Energy Suspension
    Prothane
    etc...
  9. 99sidude
    Ohio
    Sounds like you already have some kind of poly bushing, which are known to squeek alot when not lubed correctly. Regular grease won't work.
    I have energy suspension bushings on my car. They say to either use their grease, or a "marine grease" as a substitute. After about 6 months of use they became really noisy, so I used some gereric marine grease I got at autozone to fix the problem. Has worked like a charm so far.
  10. HATCHET_HONDA
    hobart, indiana
    HMMM marine grease huh? i take it that stuffs water proof? did you remove the bushings then smear the grease over the collar inside? seriously ill try anything the squeaking is driving me nuts!!
  11. 99sidude
    Ohio
    it would prolly work better if you did that, but I just smeared everything really heavily
    1 person likes this.
  12. HATCHET_HONDA
    hobart, indiana
    got an update for ya....i just got done slappin some of that marine grease all over them bushings inside and out. lowered the car down and poof!! quiet as a mouse! seems to be some good stuff and it was pretty cheap too..^_^ thanks
  13. 99sidude
    Ohio
    Nice!:cool:
