Sr20det dead as hell
Discussion in 'Other Vehicle Discussions' started by get_nick, Apr 7, 2008.
  1. get_nick
    Washington State
    while prepping the nissan to go to the insurance adjustor tomorrow, i tried to start it up....nothing.
    i'ts not the battery, i hooked up the integra with some jumper cables and let it run for a while. no dash lights, no head lights, no clock, no climate control. check the fuses, cant see shit. fuse panel is in japanese. checked the fuses in the engine bay, fuses are fine but i don't know how to check if a relay is bad. fuel pump doesn't prime, fucking nothing. headlights are broke but not grounded out.
    need some help....
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    check to make sure your getting a good connection at the battery
  3. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Make sure your grounds arent corroded as well as your battery. Check terminals and all connections in/out of the relay. If your pump isnt priming and your not getting any voltage to anything else, even with a jump box/cables than there is a failure in the main circuit from the battery, out. Also, if the battery is completely discharged this will happen as well. Take the battery to a shop and have them test it for you. Good luck, Nick! :thumbsup:
  4. NissanNiNjA2nd
    NissanNiNjA2nd Senior Member
    Ignition switch.
    btw.... good luck.
    You're probably buying 1/2 of a new car to fix this.
  5. get_nick
    Washington State
    i was thinking that, it's a pain in the ass too. i just haven't had a chance to mess with it. i can probably get one off of a clip. i get a lot of work done locally from an importer. if i jiggle his balls, i might get one for free. :mad:
  6. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
  7. George777
    George777 ^^ Likes Bewbies
    With your mom
    Electrical gremlins?
  8. get_nick
    Washington State
    about to toss in a spare battery. be back in a bit.
  9. TurboMirage
    OMG. i had this same issue with my old 240. ended up having to replace the ignition switch. while i was at it i had the locks replaced too, since i needed a new ignition.
  10. get_nick
    Washington State
    well, i decided to take the battery to get tested. it has flag pole posts rather than the regular terminals. obviously every fucking place is closed on sunday and i MUST have this working by monday afternoon.
    called around, nothing open. finally took the battery to firestone. tested it, it's too dead to hold a charge or even get jumped. obviously nobody has it. turns out my friend doug who owns a shop likes to use wheelchair batteries rather than doing a relocation for sr20 swaps.
    so now i have to find a wheelchair battery on a sunday since it's the only thing that fits with the right terminals. motorcycles shops didn't have it. couldn't find a local marina and there aren't any medical supply places open.
    so i'm driving to costco and see a sign for a rental store. you know the kind that has card tables, lawn mowers, and other equipment and shit. the lighted billboard is flashing they have wheelchair rentals. i slam on the brakes and drag marsha in. "hey do you guys rent motorized wheelchairs?" he says yes. "got any batteries?" takes me to the back and pulls out one that is identical to mine.
    how much, "$40" brand new. fucking jackpot. most of the others were $100+. take it home, fires right up. sweet.
  11. Briansol
  12. TurboMirage
    killer!
    wheelchair battery? is a miata battery too big?
  13. get_nick
    Washington State
    fuck i dunno. i think it has different electrical connection posts. and they are on different sides.
  14. nootrac22
    exeter pa
    You shoulda got a "jazzy chair" sticker to slap on your car.
  15. BigJ
    :lmao: Good call.
    Wheel chair battery? Odd.
    I go the other way and use marine batteries.
  16. get_nick
    Washington State
    tried that, but there weren't any local. and the ones i called didn't carry them.
