sr20det spark plugs
Discussion in 'Other Vehicle Discussions' started by VTECPOWER, Dec 28, 2005.
  1. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    For my sr20det i know to get sentra ser (sr20de) spark plugs, but since the det is turbo, i was wondering if anyone knew if i should get a different kind of plug ie: hot or cold, or any suggestions for that matter.
    Thanks
  2. VTECPOWER
    Winchester, VA
    So far ive read heat range 7, is there a way for someone at autozone to tell the heat range of the spark plug?
  3. Celerity
    Celerity Well-Known Member
    good question.. I work only in gaps, so I dunno. NissanNinja is the guy to talk to.
  4. Cashizslick
    From Zilvia
    Hope it helps
  5. NissanNiNjA2nd
    NissanNiNjA2nd Senior Member
    NGK Iridium:
    BKR6EIX
    BKR6EVX
    BKR6EIX-P
    read on the specifics of each of these plugs, find out how they suit what you do, then choose the right one.
  6. VTECPOWER
    Winchester, VA
    Thanks, i think i'm going to go with the #7 heat range.
  7. Cashizslick
    ^ i should know this, but i dont. . . . which ones are for the SR20DET in stock form?
  8. VTECPOWER
    Winchester, VA
    Um, i know the stock heat range is 6, but you want a colder plug with more boost. And I know down the road comes a new tune w/more boost.
