SCS Plug
It is a yellow connector with two wires in it that is plugged into the fuse box, unplug it and pull it down. Once you have
done that you can begin the process of erasing the memory. NOTE: This will only reset your SRS System if what
caused it to trigger has been fixed, Ex: turning the ignition on with any SRS Plugs disconnected, such as pulling your
seat out.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off.
SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator
light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that
memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal.
You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect. My first time it took me 3 attempts before it
worked, but it did work.
