SRS light
Discussion in 'ECU's, Electronics, and Tuning' started by SIRH22, Dec 7, 2003.
  1. SIRH22
    SIRH22 Member
    Harlingen Texas, Close to South Padre Island
    Does anybody know where the 2 pin service connector is to get codes for diagnostic information? My car is a 97 Civic EX four door. My SRS light just came on and wont turn off. I plugged a diagnostic scanner into the diagnostic plug and after entering the vehicle information the scanner said there is a 2 pin connector under the glove box that i have to use with a jumper to get codes. I have looked everywhere under the glove box with no luck in findng the 2 pin connector. Any help or feedback would be appreciated.
  2. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    It's ususally taped to the main ecu harness under the dash towards the firewall on the right side.
    You'll most likely need a flash light and possibly need to remove the ECU to get to the connector.
    Happy hunting! Let us know the outcome.
  3. SIRH22
    SIRH22 Member
    Hey thanks alot AllMotorMonster much appreciated. Ill be checking it out tommorrow. :D
