Stage 1 Weight Reduction
Discussion in 'General Tech and Maintenance' started by webink_EK9, May 4, 2004.
  1. webink_EK9
    webink_EK9 Senior Member
    Now I'm having fun and getting my hands messy. I Pulled out the seats, carpet, rear side plastic stuff and removed some old dynamat out of my car lastnight. It's startin to get fun. Only think is, I'm not looking forward to removing the black soundproof shit from my car. There's too much of it. How much time and/or $$ would it take for somewhere to take that out for me? I don't feel like getting that stuff all over me. And after I get it out, can I use some kind of sander or something to smooth the it out then have a primer sprayed? Let me know any thoughts. Thanks!
  2. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    about 20lbs of dry ice, putty knife and a hammer is all you need. If you feel like repainting it sand it down with a DA and prime it.
  3. CRX_B16B
    CRX_B16B Senior Member
    Wire wheel and a putty knife sounds good to use to me and maybe a heat gun but that would get messy.
  4. adnoh
    adnoh Senior Member
    Ontario
    In terms of sending it off somewhere to get stripped........dont even bother. You'll be paying a shop by the hour and end up waisting tons of cash.
    You might want to check the sport compact car website (www.sportcompactcarweb.com), in either an EG civic, or one of their CRX projects (cant remember which one) they used Dry ice to freeze the soundproofing, then smashed it with a hammer and it cracked off in large chunks. I used this method on my first Civic and it worked so much better than trying to use a plaster spreader and a flat head skrewdriver. Took me and a friend a day or so to complete. We then took off the remaining crap with the plaster spreader thingy, sanded with coarse sandpaper, then wet sanded with some fine paper, primed it, and a quick paint job to match everything else. Worked well. So go find some dry ice (not as hard as you might think), and have fun smashing things into small pieces.
    Wish I had pics to show you....sorry.
    L8rSk8r.
    ....seems when I was writing this someone already replied with the same info.....oops! well here it is again!
  5. B16
    B16 Super Moderator VIP
    yay area, CA
  6. swanny
    Im guessing your next question is going to be where to get it, try a local supermarket or ice cream store. ;)
  7. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    ...or better yet pretend to be a student and go to a college and buy some Liquid N2!!!
  8. HellBentHONDA
    HellBentHONDA Senior Member
    wa state
    so whats stage 2 or 3 consist of?
    drilling holes in the floor board :p j/p
    they used to do that back in the day...
  9. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    AC weighs a lot if you haven't hit that up yet
  10. jamesA
    Both the AC and PS can be removed to lighten the pulley load as well as the weight savings.
  11. webink_EK9
    No PS or AC now. Stage2 Looking at removing shit within the dash. Like all the wiring and crap for the AC and Radio and stuff. Got a big hole where the radio and temp controls used to go already. Stage3 probably removing bumper beams and and side impact beams in doors. And any other non support metal in the car.
    And DO NOT use liquid nitrogen...when you try to scrape the black shit off you'll put your screw driver right through the car...but don't ask me how I know. I guess I can try the dry ICE. There's an ICE and FUEL place around here. How long will that shit last? Keep it in a cooler? I'll start on that tomorrow.
    Oh yeah...anyone know if I can take off that center front grill thinggy with the H on it without taking off the front bumper? I was looking at it lastnight and I popped those black things off the top, but there's screws holding it to the bumper. I don't know if I'll be able to get to that or not...what do you guys think?
  12. driverunknown
    driverunknown Senior Member
    You got a type arrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr.
    It can handle a little weight ;)
  13. webink_EK9
    Tight CaaaaaaRRRRRRRRRR!
    Yeah, but if I don't need it, why not. And if I'm going to stand a chance in my class, I'm going to have to go on a fucking diet to run with some of these cars. All excess weight must go... SlimFast in the gas tank!!!
  14. E_SolSi
  15. brian11to1
    brian11to1 Senior Member
    If you are worried about weight, take the rear bumper off and cut off the un needed metal back there, I took mine off and had my neighbor cut the unwanted/needed metal off. Just on the edges and the back side of the bumper. Mine was too rusted to go any furhter. Can post pics if you are interested. Keep in mind the bumper I refer to is off a CRX so it may be different.
  16. webink_EK9
    Thanks guys! Do you smash up the dry ice or leave it in the block? And do you put it in a cooler or what when you move it?
  17. adnoh
    adnoh Senior Member
    Ontario
    It usually doesn't come in a big block, it will come in small pellets (at least thats how I got it), so you can just spread it out evenly over a small area. A cooler is totally fine for transportation. To keep the majority of the dry ice contained and cool, get a thermos and fill it with enough to keep you working for a small while....this way your not constantly opening and closing your big cooler, exposing the bulk to warm temperatures. But dont get me wrong here.......that dry ice stays freeeezing cold for a very long time.
  18. webink_EK9
    Awesome...thats my project for the day. I'll play with the bumpers tomorrow. Thanks for the info!!!!
  19. E_SolSi
    mine came in sheets about 10" square x 1" thick
    i guess it depends where you get it
