Stage 2 or Stage 3
Discussion in 'General Tech and Maintenance' started by Sergey P.A., Dec 17, 2003.
  1. Sergey P.A.
    Sergey P.A. Senior Member
    253 Tacoma
    what is the difference between stage 2 and 3.....
    I mean cluches, valve trains, stuff like that.....
    thanks.... :spin:
  2. E_SolSi
    whatever the hell the manufacturer of the specific product says it is
    there are no set guidelines of what makes one item "stage 2" and another "stage 3"
    so aside from comparing like product from the same manufacturer (ie: cams from Skunk2 stage 2 and stage 3) it is an absolutly worthless unit of comparisson
    as a general rule... when comparing like product from the same manufacturer, the higher number will be more "agressive"
    but this is not set in stone either
    basicly "stages" are fucking worthless
  3. Hatchbacks Anonymous
    Hatchbacks Anonymous Senior Member
    Anonymous
    :woo: Congratulations...that was perfect.... :thumbsup:
  4. Sergey P.A.
    253 Tacoma
    what kid of cams you think is better for my all motor GSR
    I was thinking eather type R/ cuz they cheap and add some power
    or Jun stage 3.....
    now wich one you think are the best once out there for street use......
    relieble and not too expensive....
  5. E_SolSi
    there is a HUGE difference between stock ITR cams and JUN stage 3s
    skunk cams are good for street use because they retain the stock profiles for the low lobes (if you stay out of VTEC then you get decent fuel economy and if tuned right you wont have emissions issues)
    for decent gains and street use i would say go with the Skunk 2 stage 2 cams
  6. NotUrAverage_Si
    NotUrAverage_Si Senior Member
    "STAGE 3: Full-Race Cam profiles are designed for purpose built race engines with high-rpm capabilities only! Upgraded valvetrain and extensive engine work is required for proper functioning of the Full-Race profile. Compression and engine flow must be significantly increased in order to ensure the proper functioning of the camshafts. Full-Race camshafts should be installed and tuned by professional engine builders only!"
