start problems
Discussion in 'Civic and CRX - EF' started by conweezy, Oct 17, 2007.
  1. conweezy
    conweezy 89hatch
    florida
    i just dropped in a 95 vtec 0bd1 in my 89 hatch si im getting spark and i have fuel and wen i attempt to start it, it cranks but doesnt start up i have no clue what to do any help is appreciated:confused:
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    make sure your timeing belt isnt broke, anfd then also check to make sure the motor grounds are hooked up
  3. conweezy
    conweezy 89hatch
    florida
    timing belt is good moved and removed the ground
  4. conweezy
    conweezy 89hatch
    florida
    would it make a difference if the engine is 0bd 1 and the car is obd0?
  5. AHHVTEC
    Alabama
    yes did you convert it to obd1
  6. conweezy
    conweezy 89hatch
    florida
    how do you convert obd0 to obd1 is it just the wiring harness or do i have to rewire everything else?
  7. norcalgsr
    NorCal
    You need a conversion harness at the ECU and you also will need to run the extra wires for VTEC since it's not in your stock harness.
    Rywire - Online Store
  8. conweezy
    conweezy 89hatch
    florida
    do i have to rewire the injectors?
  9. norcalgsr
    NorCal
    Depends on which ones you're using.. if you're using the obd1 injectors you'll have to remove the resistor box. I had a write up on it somewhere but can't find it.. if I do I'll post it for you, but if you search for it you might be able to find the instructions somewhere.
