Starter question, Z6 into EF hatch
Discussion in 'HYBRID -> ED-EF / DA' started by B16RacerN2NR, Jul 12, 2005.
  1. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    i'm pretty sure it would work fine. if all else fails, just put the a6 flywheel on.
  2. B16CRX
    B16CRX Senior Member
    Greenville, SC
    dont you have to use the starter that goes to teh tranny? so you would need to use the Si starter....how did you get a Z6 clutch/flywheel to work with an 88-91 Si tranny? the spline count *should* be different...
  3. 88bluehf
    88bluehf Senior Member
    Denton,TX
    im using a 92-95 starter on my 88 si tranny...works better than stock!!!
