hey everyone the other day my car was fine not a problem and the next morning it wouldn't start. The key clicks but nothing happens *knowing nothing about this problem* i got a new starter and installed it. it still wouldn't turn over so i now have to connect the solenoid bolts? with a screwdriver to start it in N. Now sense than i have checked the ignition coil fuse the starter signal fuse both under the drivers side. As well as having the clutch relay under the hood tested and its fine. I have also tried starting it when connected to jumpers and it failed still. Ignition fuse under hood also looks fine. Any ideas guys? im thinking solenoid relay the small wire?
