starting a car that has been sitting
Discussion in 'Civic and del Sol - EG and EK' started by Skydive2144, May 1, 2007.
  1. Skydive2144
    Skydive2144 New Member
    I will finally be taking the engine from my friends gsr this weekend, to put in my civic. He smashed the car just under 2 years ago and it has been sitting in his driveway since. When he brought the car there after the accident it ran perfectly still, but has not been started in just under 2 years. i am going to go over there to get it started this weekend, any advice on starting an engine that has been sitting that long? what are the chances that it will actually start up rigth away?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    90%
  3. eg6sir
    if you change the oil and have a good battery, it'll most likely fire right up
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    As a little added insurance, pull the plugs and squirt some WD-40 into the cylinders. Rotate the engine by hand (with the plugs out) a few turns, slap the plugs in it, and fire it up.
  5. 93vicb16a2
    93vicb16a2 WHATS CRACKIN??
    bfe
    i just did this i put just a little bit of motor oil in the cylinders through the plug holes and it started right up smokes a lot for a min. but it cleared up quick just dont put too much
  6. killercannible
    killercannible Senior Member
    This is my strategy when i am in this situation, don't put much in. I usually put a cap full in each cylinder.
  7. dtob
    dtob New Member
    I'd change the oil, put a couple drops in each cylinder, leave the plug wires off, turn the engine over for a little bit to build some oil pressure because its probably a little dry, then put the plugs back in, wires back on and fire it up.
