starting a new forced induction build need ur inou
Discussion in 'Engine Building' started by jdmh04, Nov 28, 2004.
  1. jdmh04
    jdmh04 Member
    he guys was sup im starting a new build and was just woundering wat u guys think about my set up , my goal is trying 2 run high 10s low 11s the hp range i want is bout 536hp to 555hp.
    my block will be a importbuilders killer b18c block with there turbo pistons and the head will be a b16 head with ferrea valvetrain and crower turbo cams and skunk 2 cam gears also with a valve job and polish the turbo will be a full race stage 4 kit and the fuel iam wrking on as week speak.
    let me know wat ya think?
  2. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    So far sounds good, Some other things to think about would be
    Hondata
    Injectors
    Fuel Pressure Regulator
    Fuel Pump
    Intake Manifold
    LSD transmission
  3. Johnnylawless
    Johnnylawless Senior Member
    You'll be happy with importbuilders work.
    his work is immaculate.
  4. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    dont skimp on fuel supply and tuning.
  5. b204dr
    b204dr Senior Member
    Minnesota
    money will be the only issue in the end - also dont forget tuning , you can buy all the parts you want..but with out tunning its pointless!
  6. 92civicb18b1
    92civicb18b1 The Trisexual
    I dunno, the motor may be capable of 9's in the proper car, but if you shove that in a stock civic you wont get under 12s.
  7. pissedoffsol
    christ..... here we go again
  8. sohcslammer
    sohcslammer Senior Member
    Bay Area
    :blink: 535 horsepower isn't enought for ya, huh?
