Starting Engine..H22/Civic
FastRCars
Member
Well , im getting ready to start the engine soon..got some plugs to wire up prop first.
Which plugs/sensors is a MUST to connect? , is the ECU sending a signal to the distrubutor if a cabel is missing and telling it not to give the plugs any spark?
Cause i almost wired everything up..and i tryed to start it but i didnt get any spark..
Do i need to have MAP sensor + oil pressure switch connected to get it to start?
Pls..need some help guys
JDM H22A / Civic Hb -94
wire properly, THEN start it.
i know, you anxious to see it start, but trust me, it will only run like shit, if at all, with sensors unplugged.
