starting issue ls swap
Discussion in 'Civic and CRX - EF' started by spacemanspiff, Sep 1, 2009.
  1. spacemanspiff
    spacemanspiff New Member
    outside philly
    i had a b18a before now i have a b18b1 from a 94 or 95. i can get it started but only for a second probably less i have spark and i have fuel. im wondering if its because i took the icm out of my old dizzy and put it in the new one because the old one was fried. could that be the reason or could it be because i have bad gas. please help me im getting pissed off with it and i want to finish this swap soon.
  2. D16SiHatch
    D16SiHatch New Member
    do your ecu and dizzy obd# match? if not, they need to.
    any codes?
  3. spacemanspiff
    outside philly
    i havnt checked for codes yet i think its the obd of the pcm and the dizzy.
  4. spacemanspiff
    outside philly
    are the icms in the dizzys the same or atleast inerchangable.
  5. D16SiHatch
    some igniter modules are interchangeable and some are not. if you check your codes and see a code 15 for the igniter then you'll know thats where your problem lies.
  6. spacemanspiff
    outside philly
    ok well if i have spark its probably not the igniter. right?
