Starting Problem, need to locate Starter relay.
Discussion in 'Accord' started by 93civicracer, May 4, 2009.
  1. 93civicracer
    93civicracer Oh, I do a little here and there.
    Just on Friday my car quit starting, but it starts and runs fine with a push which I've been doing 4-5 times a day.
    Put on a new starter, nothing.
    Tested ignition switch, it's reading fine.
    Leaves 2 possibilities I can come up with:
    Some kind of clutch safety switch (can't locate that to test either)
    And the Starter Relay (can't locate it, Haynes says it's below the main relay below the dash on the left, but none of the relays are labeled, and the manual doesn't say which is which.
    I called Honda for a price on the relay so I could just guess and check, they don't even know which one it is. So they told me to call Napa for a part number, they didn't know either.
    Does anyone know where that starter relay is, or which multi-function relay the starter uses? I'm assuming the main relay is fine because the car runs great with a push start still pullin strong at 187k miles no problems.
    Help! lol I'm tired of pushing. Photos or some way to identify would be much appreciated!
