Alright i have been working on my 95 del sol trying to figure it out. I just bought a 95 del sol. the lady said it was an ignition swithch so i pulled it off and rigged it to get it home. I pulled the spring off the switch and turned it till it cranked and started then i backed it off to keep it running and get it home. it cranks and begins to start but dies right after. wont even idle. tried starting it and hitting the gas thinkin iac but no luck. swapped the ignition swithch and harness and still the same. I think the engine was replaced at somepoint cause its a d16y7 with a crank sensor that is just sitting there doing nothin (not plugged in nor has wiring to plug in.) i think they swapped motors and left the oem ecm in it. but i dont understand how i started it and got it home. If anyone has any ideas, advise, tips or even slightly possible ideas to try it would appreciated. im at a loss
