Starting Problem
BillW
Honda engine in 1991 Acura - 6 cylinder. After driving (the engine is hot) it often will crank but will not start. After waiting an hour or so it will start. Possibly causes??
Thank you,
Bill
Thank you,
Bill
[post=539899]Quoted post[/post]​
Overheating maybe... :shrug2:
main relay or something similar. Coil, ignitor (thast in teh distributor)...could be several things. Have you done a tune-up recently?
usually when a car heats up and either turns off or wont start...its the coil in the dizzy
