starting problems
Discussion in 'Engine Building' started by that_one_dude, Sep 27, 2004.
  1. that_one_dude
    that_one_dude Member
    WI
    <_< alrite. heres the story.. i had my car running and then i had to fix the timing belt so i did that all right and now my car wont start.. it cranks but wont turn over.. i checked everything and they all seem fine. everything turns but there is no spark... im thinking it something electrical.. cuz sometimes theres no sparks... i used a new distrubitor, new spark plugs and wires but it still wont turn over or spark..i resetted the ecu and im out of ideas now.. any one know what is wrong give me a clue or some help.... :)
  2. sihatchback_RL
    sihatchback_RL Senior Member
    turn your motor to TDC on number 1 cylinder and open up your distributor cap. make sure that the rotor sits on the number one tooth. then put on your cap and onto your motor. sometimes the thing on the distributor is switched backwards and get a messed up ignition timing.
  3. pissedoffsol
    yup- sounds like your cam VS crank timing TDC marks are not correct.
  4. hondanamics
    hondanamics Member
    i did the same thing and have the same problem. can u give more details please what if it lines up right but still wont start. what else can u try.please help how do i know for sure that it is tdc on number one cylinder. and how do i tell if rotor is number one tooth
  5. hondanamics
    hondanamics Member
    ne one
  6. shithatch
    shithatch Junior Member
    Urbana, Ohio
    if u put a new timing belt on it u would want to double check your water pump and crank to make sure they are ready to roll when it is fired. They all have marks that are supposed to be lined up. pop your cap off and i believe tdc is when the rotor is pointed up and towards the left diagonally.
  7. nocturnalhatch
    nocturnalhatch Junior Member
    the cam timing marks should be line up on each other and the arrow pointing up says up, and the timing pointer to the white line on the crank pulley.
