Starving for Fuel or Dead Ignition?
Discussion in 'Integra' started by PyrateMate, Oct 3, 2012.
  1. PyrateMate
    PyrateMate New Member
    I have a 94 Integra LS with a vtek engine. The car sat for several years and last month I replaced the ignition coil, battery and fuel pump. It ran great till this morning. On the interstate the power suddenly fell off like it was starving for fuel. I was able to limp the 14 miles back home on back roads.
    All the while the car would run for about 1 minute and then begin to sputter, loose power and come to a stop. At times it would stall out, back fire slightly and coast to a stop. Once it sat for about 1 minute I could start it and it would repeat the process. At one point I even got a police escort to the parts store. LOL. Changed the fuel filter, car started right up and ran for about 5 min. Took for a test ride and it started all over again.
    Any ideas??
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    any check codes on,? and it sounds like its out of time
  3. PyrateMate
    No codes and no check engine light either.
  4. Briansol
    a similar thing happened when my o2 sensor wiring melted and shorted out. check that wiring and fuse.
  5. dc4dude
    dc4dude Member
    chicago, il
    might also be bad fuel dude...
  6. Fernpatch
    Fernpatch Member
    Bellingham,WA
    Igniter problem?
  7. PyrateMate
    Where can I find the Igniter? and How do you test it?
  8. Fernpatch
    Fernpatch Member
    Bellingham,WA
    The igniter is in the distributor near the coil. The best way I know to test it is to check for spark when the engine shuts dies and won't start. When the igniter fails it will usually be due to heat buildup causing a high resistance on the internal circuits.
    If you have a heat gun you can try to start the engine when cold to verify that it runs. than shut the motor off and remove the distributor cap. Using a heat gun (or a burly hair dryer) get the igniter good and hot. Than quickly install the distributor cap before it has a chance to cool down and see if the motor starts and runs.
