Spyderturbo
hey guys, did a static compression test on my 2000 Civic EX today. Standard procedure, pulled the fuel pump fuse and the ingnition fuse. Car uses zero oil, zero coolant, runs great, did a compression test just because I could. This is what I cam up with, starting from timing belt side, to dist. side.
235, 235, 230, 235
seemed a little high to me, but nonetheless very consistent. Car has 144K miles, I just relaced the catalyst due to failure. Looking for thoughts on the results. I'm thinking that there is some carbon deposits influencing the results. Car runs great, plugs burn clean, as does the exhaust (now)
235, 235, 230, 235
