Steering Wheel Shakes..tire Vibration..
Discussion in 'Wheels / Suspension / Tires / Brakes' started by JrSiRb16A, Feb 11, 2003.
  1. JrSiRb16A
    JrSiRb16A Senior Member
    Daytona Beach, FL
    sup peoples..yo i need some help..my steering wheel shakes a little and pulls to the left..i know it needs a wheel alignment and the boot on left axle is no good..im replacing soon..but then i also get a sligth tire vibration when i give it gas in low rpms..i have 91 Civic B16a...Tokico Blues..H@R Springs..Upper front strut bar..Ingalls Camber Kit..17'" wheels..all stuff is within two months old..would the bad boot on axle cause this or the wheel alignment...also i hear a slight noise comin from right front wheel...it sounds faint but i can hear it wind up when i speed up and wind down..when i release the gas..anybody know?..
  2. JrSiRb16A
    Daytona Beach, FL
    i was also told that becuz i have place racing mounts..i will feel more vibration.. cuz the rubber in mounts is differnt then the rubber used to make stock mounts..???is this true??
  3. pissedoffsol
    yes. its stiffer and you will feel more vibration.
    have you done an alignment recently? hit a curb?
  4. JrSiRb16A
    Daytona Beach, FL
    yeah..the car needs a wheel alignment..it pulls to the left a little..its prob off about a inch or so..but..i didnt hit any curbs..lol..
  5. AlphaSonicB20
    AlphaSonicB20 Junior Member
    Where the Hadji's Live
    also check to make sure you lug nuts on the rim are tightened down, i had the same problem after I left pep boys one day to change my brake pads and them fooker aint tighten all the bolts all the way, its little shit that can contribute to large problems
  6. Prowler
    Prowler Super Moderator
    B MT
    If they're new wheels, you've got to retighten the lugs after 50 miles or they will loosen up and your wheel(s) could fall off. No joke, it's happened several times here in town according to one tire shop.
  7. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    My friend had a similar problem..the going to the left thing is simply an alignment problem...but the shaking thing in my friend's case turned out to be a f*cked up intermidiate shaft...and since you said it was on the left side where you could hear the noise coming from...that is the side the shaft is on, so check that out and see if it's that
