not sure about how well they will match up, but the air bag thing isn't all that hard..
1. disconnect the battery, completely!
2. rotate the wheel 180 degree's. so the access pannel is facing up. remove the panel, and remove the short connector from the access plate(stored on the inside of the access plate) . unplug the airbag modual-to-cable reel connector and plug the short connector into the airbag modual side of this conector to disable the airbag modual
3. remove both torxscrews from the side of the steering wheel, facing toward teh dash.
4. pull off teh airbag modual, and set aside, facing up./
5. unplug the electrical connectors for teh horn and CC.
6. remove the steering wheel retaining nut. make a mark indicating the relationship of the steering wheel hub to the steering shaft.
7. remove the steering wheel by pulling it straight off the shaft.
these work on a 5th gen civic, so i'd assume they would work on your's as well..
