Originally posted by EGLSHB@Oct 14 2003, 04:28 PM
depending on the trim level of the car... if the LS is OBD 1, it is a no-brainer... you just take out the old motor, and bolt the other one in it's place.... there is virtually no wiring to do, and everything plugs up... i did one in my 92 vx in 5 hours
which isn't bad, since that was also including getting the exhaust welded up
