Still working on the LS swap
Incredib1e
OK I might be buying a 99 B18b soon and was wondering where do I get the conversion kit for the OBD, My car is a 98 hatchback so I need OBD2b or something like that. Whatever the difference is between a 96-98 LS integra and 99-00 integra. Thanks for whatever help I can get.
all of the plugs on the engine will be the same ... just get an OBD-2a LS ECU and youll be fine
just have to lengthen a few wires on your harness
Never mind turns out the car is a 96 which makes it better
won't have to worry about wiring. It should just drop in right. Use the stock motor mounts for the integra?
