Stock 89' Hf Turbo Oil Feed Line
Discussion in 'Forced Induction' started by b18vtecrx, Mar 30, 2003.
  1. b18vtecrx
    b18vtecrx Senior Member
    ok like it says on the title im putting a turbo on my stock 89' HF and its a home made kit too and since homemade turbos cant be loaded on my shitty computer can somebody send me a link to any websites on how to tap the dam oil pressure sensor i have taken off the weather guard from the sensor and now there is a HUGE nut holding the sensor in now i need to know what to do now i have searched through the forums and found nothing helpful to my question so please do what you can to help me with any explainations and pics of all sorts...thnx VERY much guys
  2. pissedoffsol
    here's a shit load of links from Honda-tech
    this was posted a year back or so....
    http://www.honda-tech.com/zerothread?id=67146 -oil return
    http://www.honda-tech.com/zerothread?id=109160 -oil return line setup
    http://www.honda-tech.com/zerothread?id=114490 -oil return line parts
    http://www.honda-tech.com/zerothread?id=71999 -where to weld oil return
    http://www.honda-tech.com/zerothread?id=119100 -oil return line
    http://www.honda-tech.com/zerothread?id=119539 -oil pan welding
    http://www.honda-tech.com/zerothread?id=119715 -oil pan welding
    http://www.honda-tech.com/zerothread?id=118687 -oil grade to use
    http://www.honda-tech.com/zerothread?id=118694 -ft for oil feed line
    http://www.honda-tech.com/zerothread?id=118807 -oil feed line
    http://www.honda-tech.com/zerothread?id=119681 -oil feed line
    http://www.honda-tech.com/zerothread?id=93550 -part for oil feed line
    http://www.honda-tech.com/zerothread?id=114436 -where to buy brass t for feed line
    http://www.honda-tech.com/zerothread?id=126335 -oil t question
    http://www.honda-tech.com/zerothread?id=125438 -another place to buy oil lines
    http://www.honda-tech.com/zerothread?id=131447 -oil feed line an/npt connector ?
    http://www.honda-tech.com/zerothread?id=134078 -feed diagram
    http://www.honda-tech.com/zerothread?id=133948 -oil bpst fitting again
    http://www.honda-tech.com/zerothread?id=144586 -oil feed line restrictor
    http://www.honda-tech.com/zerothread?id=155510 -oil leaks
    http://www.honda-tech.com/zerothread?id=158018 -oil feed 3' better
    http://www.honda-tech.com/zerothread?id=156571 -oil pan bolts
    http://www.honda-tech.com/zerothread?id=170223 -oil pressure readings
    http://www.honda-tech.com/zerothread?id=168084 -oil feed fitting
    http://www.honda-tech.com/zerothread?id=131450 -oil feed diagram
    http://www.honda-tech.com/zerothread?id=195068 -oil pressure
    http://www.honda-tech.com/zerothread?id=122635 -drag 3 (to) coolant line?
    http://www.honda-tech.com/zerothread?id=116891 -closed loop turbo info
    http://www.honda-tech.com/zerothread?id=119724 -drag 3 turbo fitment (filing block)
    http://www.honda-tech.com/zerothread?id=119690 -vacuum source
    http://www.honda-tech.com/zerothread?id=94820 -closed loop
    http://www.honda-tech.com/zerothread?id=120814 -Drag3 downpipe
    http://www.honda-tech.com/zerothread?id=120867 -Drag3 + Tial connection
    http://www.honda-tech.com/zerothread?id=118699 -wastegate vacuum line
    http://www.honda-tech.com/zerothread?id=118767 -feul pump for drag 3
    http://www.honda-tech.com/zerothread?id=121442 -fittings (brass T on block)
    http://www.honda-tech.com/zerothread?id=123326 -blow off valve tightening
    http://www.honda-tech.com/zerothread?id=123925 -catalytic converter removal o2 sensor
    http://www.honda-tech.com/zerothread?id=124474 -'burning' in the turbo + blow off valve ?
    http://www.honda-tech.com/zerothread?id=124580 -drag 3 manifold boost spike issues
    http://www.honda-tech.com/zerothread?id=124662 -drag 3 tial fitment
    http://www.honda-tech.com/zerothread?id=151845 -closed loop dump tube
    http://www.honda-tech.com/zerothread?id=155616 -flexpipe issue
    http://www.honda-tech.com/zerothread?id=159889 -blow off valve adjusting/cleaning
    http://www.honda-tech.com/zerothread?id=163453 -egt probe tapping
    http://www.honda-tech.com/zerothread?id=167329 -o2 sensor bung
    http://www.honda-tech.com/zerothread?id=170498 -don't use tial gasket
    http://www.honda-tech.com/zerothread?id=175270 -intercooler direction
    http://www.honda-tech.com/zerothread?id=175277 -drag bolts suck
    http://www.honda-tech.com/zerothread?id=206376 -bov greddy type s (loose)
    http://www.honda-tech.com/zerothread?id=120548 -hondata install (solder stuff)
    http://www.honda-tech.com/zerothread?id=98092 -hondata install heiarchy
    http://www.honda-tech.com/zerothread?id=121859 -hondata info on pumps
    http://www.honda-tech.com/zerothread?id=117300 -spark plugs
    http://www.honda-tech.com/zerothread?id=156273 -spark plugs (2)
    http://www.honda-tech.com/zerothread?id=116886 -changing plugs
    http://www.honda-tech.com/zerothread?id=117326 -flexpipe for good price
    http://www.honda-tech.com/zerothread?id=117733 -injectors, 440 or 550
    http://www.honda-tech.com/zerothread?id=119569 -guage for autometer
    http://www.honda-tech.com/zerothread?id=119591 -autometer guages
    http://www.honda-tech.com/zerothread?id=121452 -aero fpr
    http://www.honda-tech.com/zerothread?id=119884 -best FPR?
    http://www.honda-tech.com/zerothread?id=118885 -place to buy aem fpr
    http://www.honda-tech.com/zerothread?id=122590 -(installing) aeromotive fuel regulator
    http://www.honda-tech.com/zerothread?id=86051 -removing/installing intank fuel pump
    http://www.honda-tech.com/zerothread?id=120889 -profec b install
    http://www.honda-tech.com/zerothread?id=116651 -Radiator fans
    http://www.honda-tech.com/zerothread?id=119819 -diff between mechanical/electrical gauges
    http://www.honda-tech.com/zerothread?id=117513 -turbo XS boost controllers and tial wastegates
    http://www.honda-tech.com/zerothread?id=122396 -block guard
    http://www.honda-tech.com/zerothread?id=107030 -rc 440 injector polarity
    http://www.honda-tech.com/zerothread?id=82211 -rc 440 after hondata install
    http://www.honda-tech.com/zerothread?id=121452 -aeromotive fpr part #
    http://www.honda-tech.com/zerothread?id=125639 -hks ssbv clip
    http://www.honda-tech.com/zerothread?id=153531 -more hks bov install
    http://www.honda-tech.com/zerothread?id=125852 -carsound cat part #
    http://www.honda-tech.com/zerothread?id=92570 -turbo timer relay
    http://www.honda-tech.com/zerothread?id=128321 -turbo timer wiring
    http://www.honda-tech.com/zerothread?id=132485 -radius rods
    http://www.honda-tech.com/zerothread?id=63095 -rear seat removal
    http://www.honda-tech.com/zerothread?id=133644 -injector fitment
    http://www.honda-tech.com/zerothread?id=104940 -thermal to cat issues
    http://www.honda-tech.com/zerothread?id=136680 -egt guage stuff
    http://www.honda-tech.com/zerothread?id=137223 -which runner to tap for egt
    http://www.honda-tech.com/zerothread?id=55987 -aem fpr against strut bar
    http://www.honda-tech.com/zerothread?id=139706 -tools to carry
    http://www.honda-tech.com/zerothread?id=140003 -base fuel map
    http://www.honda-tech.com/zerothread?id=140774 -bleeding coolant
    http://www.honda-tech.com/zerothread?id=156073 -js safeguard
    http://www.honda-tech.com/zerothread?id=168470 -js safeguard, who is using
    http://www.honda-tech.com/zerothread?id=160428 -summit part
    http://www.honda-tech.com/zerothread?id=170160 -9psi, raise static fuel + retard timing
    http://www.honda-tech.com/zerothread?id=170821 -wires to tap for guages
    http://www.honda-tech.com/zerothread?id=171397 -c clamp pliers for hks bov
    http://www.honda-tech.com/zerothread?id=171314 -EGT temps
    http://www.honda-tech.com/zerothread?id=166449 -vacuum sources
    http://www.honda-tech.com/zerothread?id=175335 -assembling an fittings
    http://www.honda-tech.com/zerothread?id=176725 -oem fan clearance - move to right
    http://www.honda-tech.com/zerothread?id=193263 -greddy profec b
    http://www.honda-tech.com/zerothread?id=85987 -installing rc injectors
    http://www.honda-tech.com/zerothread?id=106033 -matching wires rc injectors
    http://www.honda-tech.com/zerothread?id=133644 -fitment of rc injectors
    http://www.honda-tech.com/zerothread?id=107030 -polarity does not matter
    http://www.honda-tech.com/zerothread?id=154935 -once installed
    http://www.honda-tech.com/zerothread?id=159623 -tips to install
  3. b18vtecrx
    the pics on thos links arent working so can somebody gimme some different pics and explanation on what to do???
