bed floor is a pain in the dick
you basically pull the bed side, cut out the inner bed side, and then put it back together
gets tricky when you want to hide the welds under the bed rail and you need to keep it square and it has to match the other side
we only have the one side cut off and fit so far, not welded yet, but that should be the easy part
the floor was raised about 7 inches
sucks when you cut your stock bed to clear the notches, then decide to go with a body drop and stock floor
not such a big deal with an s10, beds are cheap
tacoma beds are rare, especially with no rust, and expensive as fuck
at least its not a ranger
