elcangripapiex
Member
I need to know if I should buy the ls ECU for a turbo setup or buy some other computer to controll the High Vloume fuel rail and reg. with 720cc injectors
[post=389315]Quoted post[/post]
yes, it will throw a code, cut timing, and all that.... but its at about 3 psi that this happens.Correct me if im worng. Once manifold pressure is more then 1lb the ecu generates an error code?
