Stock Fuel Lines
Discussion in 'General Tech and Maintenance' started by Frank_Li, Apr 22, 2003.
  1. Frank_Li
    Frank_Li Member
    El Paso, TX
    Ok, If I upgrade the fuel pump and injectors how much would stock fuel lines flow before they starve my engine? I also read in another website that the stock ECU can run bigger injectors as long as they are calibrated correctly, is this true?
  2. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    You don't need to worry aobut the fuel lines til you reach OVER 450 at the wheels. Then some larger braided stainless lines are suggested.
    The facotry Honda ECU's can LEARN up to 310cc injectors. make your you use saturated or peak and hold style injectors compatible with your ecu.
