STOCK GSR MOTOR? How do see if it is good
96coupeb18
Stock GSR Motors are 10:1 Compressions as far as I know , and how and where can I take it to be compression tested,so I can make sure the pistons and rings are still working good. I heard there is a tool I can use to see , and it measures it in PSI, if so what is a stock GSR Motor from a 95 teg should be putting out, thanks for the help
