Stock Rod Strength
Discussion in 'Engine Building' started by 79civicsi, Nov 22, 2005.
  1. 79civicsi
    79civicsi Junior Member
    Hey, I am planning on putting some 11:1 cr pistons in my d16a6 and I was wondering if I could get away with just the stock rods, I will most likely be reving the motor fairly high on numerous occasions. Any advice would help, thanks.
  2. pissedoffsol
    you'll probably float a valve before you snap a rod :p
    upgrading the rod bolts couldn't hurt though. ARP makes some nice ones for about 50 bucks.
    just make sure you install them right. i'd recommend a machine shop doing it, as they need to be stretched/trqued correctly...
