Straaaange....
Discussion in 'Engine Building' started by mattcalica, Apr 19, 2003.
  1. mattcalica
    mattcalica Senior Member
    okay, i am having a little problem with my b16...my number 2 spark plug wire keeps popping out...like after i drive around a few minutes, i notice that my car is lagging, so i check under the hood, and the spark plug wire is popping out of the valve cover...not all the way out, but it is sticking out a good bit...anybody have any idea what the problem is? oh and these are brand new spark plug wires too, so its not the clips...
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    How tight is the wire?Is it a fitted set,or did you get a kit?
  3. mattcalica
    its made for my car...the rest of the wires stay in, its just that damn #2 cylinder wire...
  4. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Are they OEM honda wires? If you think that the wires are ok, pull the plug out, see if it is messed up in any way.
  5. mattcalica
    nope, they are accel wires, but i looked at the wires and they are not messed up...
  6. pissedoffsol
    some aftermarket ones just don't fit right dude. get ngk's or oen honda
  7. ITR Hatch
    ITR Hatch Junior Member
    Same thing that happened in my gsr. the #4 spark plug blew the fuck out and broke my carbon fiber wire conver in half. check the spark plug gaping. :(
  8. D See 2
    D See 2 Senior Member
    Baltimore, MD
    sounds to me like your getting blow-by through the spark plug threads. check to see if the plug is tight. if it was overtightened in the first place then that could cause this also.
  9. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    yea make sure it's tightened up to spec
  10. cws13
    cws13 Senior Member
    Athens,GA
    That's what I'm thinking. Something outside of bad fitting is going on. You can hold a sparkplug wire almost all of the way out of the head and the spark will still jump to the plug and fire. Sounds like it's bleeding off compression, there will be black/brown blow by in the tube if this is the case. You woould probably have heard the noise already though...
  11. zueke
    zueke Senior Member
    Lansing, MI, USA, Earth...
    I've had the same thing happen on my car with NGK spark plug wires and NGK Irridium plugs. This is what I've come up with: I don't think that the plug snaps in perfectly with the wire, so I just took a little bit of silicon sealant and put around the flange where the valve cover meets the plug wire (on the outside of the flange so it wouldn't dribble down to the spark plug) I let the stuff dry overnight and checked the next day to see that the plug was secure before driving on it. Since then I haven't had any problems, which was 10 months ago.
