Stressed out,code 08 TDC,everything checks out good!
Discussion in 'Civic and del Sol - EG and EK' started by c_champagne, Jul 27, 2011.
  1. c_champagne
    c_champagne New Member
    94 del sol ,d16y6, throwing code08.TDC sensor,faulty sensor or connection.
    Changed distributor and ohms are above 400,continuity of orange and orange/blue all the way to ecu pin outs good.Unmolested car and wiring in great condition.
    Any ideas on what elese could be causing fault code 08 TDC?
    Also checked with another ecu and throws same code,also code was present on original distributor and as per code replaced.
    Have double checked timing visually by removing both covers and checking both cam and crankshaft timing in relation to timing belt and with timing light at harmonic balencer.Set at red mark (16*) with standard timing light.:confused:
    Question? - Do I need an adjutable timing light?
    It will have a hard start issue and wife says it will have low rpm fluctuation,as if in limp mode possibly,this is her daily driver and commutes with.
    Remember,completely stock,unmolested car,never any issues with ecu and ecu has been checked with another known good ecu.Connections good to ecu pinouts and distributor checks out good.
    Wrap your brain around this one,because it has me really stumped.
  2. monotech
    monotech Member
    Check the Orange/Blue stripe wire and White/Blue stripe wire make sure they aren't reversed. Check both sides on the Distributor/plug side and ECU plug side.
