Stripped lug nut
Discussion in 'Wheels / Suspension / Tires / Brakes' started by cheese9988, Jul 2, 2005.
  1. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    One of the lug nuts on the crx are stripped and I cannot get the wheel off, the nut just keeps spinning on the bolt. I have tried a prybar between the wheel and the hub and put an impact on it with no luck and maybe this has made it worse. Can anybody make any suggestions on how I can get this thing off? I can't torch it because the rims are half way decent too.
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    drill the bolt out maybe?
  3. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
    Cut the lug off the stud?
  4. abdelsol
    abdelsol Member
    Use a die grinder and remove the flange on the stud. Then pry it off. If you do it this way becareful when you pry, no point in screwing up the hub flange or stud hole.
  5. cheese9988
    Lowell, MA
    Hmm, think I can get a grinder in there?....the lugs are recessed into the rim, they don't stick out at all. I could try a drill, just be ALOT of drilling on something like that.
  6. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    he is suggesting going throught the back and cutting the stud there. Drilling will work but as you said, it will take forever.
  7. cheese9988
    Lowell, MA
    Ya, no room for a grinder back there...wish I had a pic of the rims.....guess the drill will have to do.
  8. E-dogg
    E-dogg Senior Member
    Make sure ya use a really good drill and bit... I did this on one of my rex's and it took forever. I had a shitty drill and bit though so I imagine you can get through it fairly easy with something high powered and made to go through metal.
  9. MadMaXXX
    MadMaXXX Mad Man
    USA
    ye happened to me once
    eneded up using a prybar while racheting out w/ a pnematic tool
    that was the only time i regretted geting my 15 spoke wheels or else a grinder would have fit
  10. asmallsol
    why not try one of those rounded bolt removers from craftsman. It sould take it off, and it will be a hell of alot easier.
  11. cheese9988
    Lowell, MA
    An easy out?
    Well I did get it out, 2 hours of drilling, and swearing at that pos thing. Nicked the rim up a couple of times, but I painted them afterwards anyway. I used my new drill bits and got a 1/2" one from sears and that got it out.
