Stroker Kits
Discussion in 'General Tech and Maintenance' started by civic_ferio, Apr 5, 2003.
  1. civic_ferio
    civic_ferio Junior Member
    hi. i was just wondering how does it work? can you cange the displacement just by changing the crank shaft?
  2. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    it's all about the math.
    If you increase the stroke on the crank, the piston will push further upward, so you either:
    A: get a shorter rod and shoot the rod/stroke ratio to shit
    or
    B: Move the wristpin in the piston upward, possibly causing oil management or compression issues.
    It's really a tradeoff, but alot of companies are making some nice stroker kits now for B series cars that have a decent Rod/Stroke ratio, while they increase displacement .1-.2 liters.
  3. civic_ferio
    so you can just increase the displacement of the engine without reboring it?
  4. phunky.buddha
    Dallas / Fort Worth, TX
    Yes, but at the cost of a lot of those stroker kits on the market, it might be cheaper (or the same price) to bore out larger and run custom pistons. Your engine will be stronger with a new sleeve built to handle the larger bore too.
  5. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    heres the equation for displacement: (B/2)²*pi*S B=Bore, S=stroke. if you change the stroke, the total would be greater.
    ie. B16a2.. (8.1/2)²*pi*7.7= 397.78*4 (for 4 cylinders)= 1587cc
    r/s= 1.74
    throw in a b17 crank... (8.1/2)²*pi*8.14=419.45*4= 1678cc
    your r/s ratio will decrease though, r/s= 1.62 (this is still pretty good)
    or you can change the bore.... b16a2 84mm rebore=
    (8.4/2)²*pi*7.7=426.72*4= 1707cc, you get same r/s ratio but more displacement.
    combine them... b16a 84mm rebore, b17 crank=
    (8.4/2)²*pi*8.14=451*4= 1804cc
  6. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    how are you getting the rod to stroke ratio?
  7. NoJokE
    NoJokE Senior Member
    why do you represent bore as 8.1 and stroke as 7.7?
  8. phunky.buddha
    Know the rod lengths, divide by stroke length. :)
  9. phunky.buddha
    Centimeters... since we calculate displacement as cubic centimeters, not cubic millimeters. It's just easier to start with the right measurement scale than try to convert it later and get confuzzled.
    :lol:
  10. K2e2vin
    Raleigh, NC
    :werd: :withstupid:
