Stroker vs. Turbo
Discussion in 'Engine Building' started by austin20110, Oct 14, 2008.
  1. austin20110
    austin20110 New Member
    Northern Va
    Which do myou think is best.
    hp wise lol
    Was thinking about putting the full crower stroker kit in my b18 but cant decide if i want to turbo it instead i know you cant do both because the compression ratio would be off the charts...
    So what do you think.. and you what do you think.... this isnt one of those questions where i want someone to spoon feed me what i want to know just a personal opinion kinda thing.... dont tell me to go do my research lol its just a poll... thanks guys
    me personally leaning towards the stroker kit.
  2. efhondakid
    Akron-Canton, Ohio
    Go with boost. All motor builds are a great way to spend $10K and only make 200 at the wheels, just not worth to me.
  3. |Chaz|
    |Chaz| Well-Known Member VIP
    Turbo > All motor. Boost. Is. Always. Better.
  4. ejclide
    ejclide Swapper for life!
    OH---------IO
    If you're looking for HP, boost. you'll be happier. HOWEVER, I'll just chime in with my 2 cents, if you want a very torqey (sp?) and very quick revving motor with great throttle response and no turbo lag, that crower kit might be up your alley. I'm looking at the same kit simply because I think I might like it more coming out of turns and whatnot on the track. I just don't have 2k to blow on it!
    However, there's no one saying that you can't use both the stroker kit and the turbo. Yeah, it'd be expensive, but you'd have a killer motor. Just get very low compression pistons (I'm sure wherever you buy them from can help you find appropriate pistons), and make sure you get a GOOD tune from a GOOD shop! Hope you caught my emphasis on "GOOD".
  5. newb
    newb phresh VIP
    Backwoods Northwest
    Turbo. The only reason I could justify buying a stroker kit is for the stronger crank. Somethin tells me though, your not tryin to make 800 horse which means youd be throwin your money away on that stronger crank. Just put pistons, rods, and ARP in your block with OEM bearings, boost it, and enjoy.
  6. Matts96HB
    Matts96HB . Moderator VIP
    If you like that low end grunt, slap a little dsm turbo on there. T25 or somewhere around there, that'd spool really quick and give you some low end power.
  7. Matts96HB
    PS, what happened to your "70 trim S2000"?
  8. danse
    danse Junior Member
    If you don't want it a dog off of boost you could do what I did. I took a B16A, under drive pulleys, puck clutch, Alum flywheel, bored and ported manifolds, and throttle body, ported head with GSR cams, ARP head bolts and added a T3/T4 turbo 57 trim I chipped and using a wide band I tuned it to 10 psi on pump gas. It run's extremely well and is razor sharp to throttle. I don't drag race but I get roll on's all the time for people trying me. I am very happy with how it came out.
    1 person likes this.
  9. danse
    danse Junior Member
    I would suggest not to use the T25 turbo, it does spool very fast but will run out of air on the top end fast, make sure you correctly match your engine to turbo size for what you want to do.
  10. newb
    newb phresh VIP
    Backwoods Northwest
    If hes not tryin to make a lot of power up top, and wants a nice torque curve then the T25 would be a good match.
  11. SlushboxTeggy
    NJ to MA to CA
    BC kits allow you to pick your compression. If you intended on doing both that is.
  12. austin20110
    Northern Va
    kinda forgot to mention it got rear-ended before i bought it lol....sorry for talking shit like that I just got pissed off when everyone started attacking me about do your own research and shit.... but yea its a great car from the seats forward lol... was thinking about making it a project car(straighten the frame, replace the diff, all that good stuff) because right now it will go NoWhere! But yea would like to apologize to everyone for being a dick especially brutal,chaz everyone that gave me negative rep lol...
    So yea again sorry for being a dick, but i thought this was a place for people to ask questions and get answers,given they arnt retarted and they tried to do a little research... so yea please stop giving me negative rep everyone lol
    and i promsie to do my own research from now on and only ask when i really need the help.. and i will contribute as much as i can but please continue to correct me if im wrong
  13. austin20110
    Northern Va
    Would that be safe... I know a stroker kit will raise the compression ratio because it will use a bigger crank and adding a turbo will raise the compression even more. Is there such thing as too much compression,without having to spend 10k in gaskets,rings and other shit.
  14. Matts96HB
    I can't lie to ya, if you buy good stuff, turbocharging is expensive.
    If I were you, I'd sleeve the B18, get a decent set of pistons/rods, use OEM bearings, seals, etc. and get a peakboost kit, tune it on CROME, call it good. You'll be satisfied.
  15. austin20110
    Northern Va
    I like how we go from fighting on one thread and then buddy buddy on the next one lol... lets stick with the buddy buddy
  16. mintoxik
    mintoxik Member
    Oceanside
  17. SlushboxTeggy
    NJ to MA to CA
    Compression has to do with the pistons. A stroker kit raises displacement, not compression. But a stroker kit PLUS a turbo kit may run in the neighborhood of $10k when all is said and done.
  18. reikoshea
    Dallas, TX
    spending money + hp = happiness though :(
  19. efhondakid
    Akron-Canton, Ohio
    The storker kit is like $2000 alone, for that much I would just piece together my own kit and get a good tune on like 7lbs, walk all over the same car with the stroker kit, and still have money left over.:D
  20. austin20110
    Northern Va
    How much boost is everyone running??
