Not a good day for my sol
Started out last night, the roadcourse is 3 hours away from my house, and it started around 7, so I was not about to wake up at 3:30 and start driving, so I drove the night before. Since I am on a cheap budjet, I ended up just sleeping in my car at a nearby parking lot. When I become a bum, I will not be buying a sol. Defently no winabago.
First 4 sessions went well. With my new Azenies, I was able to hold the lines alot easier then my last visit. There was a very cocky guy in an S2k that didn't know how to drive worth shit. Because this was just speedtrials (non compition), you can only pass when the slower veichle ahead of you signles. Well this jackass wouldn't let anyone pass. I road his ass 10 ft from his bumper for 5 laps straight. Finally I got sick of it, and took a hot pit to get away from him. I told the safty guy to have them start throwing out the passing flag, and talk to the s2k guy. Wasn't a problem after that. (S2k guy was an asshole, and cocky as hell. First, coming down the parking lot, he does a quick 0-100 dash. Fucking asshole. Then he had zero experience, signs up in advanced. Coming out of the pits, he goes off course hard (there like no way to actually do it, guess they guy actually does have talent) so they threw him in begginer class)
After driving with a few more advanced drivers, I tried to push my car a little more on the fifth session. I was coming through a midspeed (around 55-60mph) sweaper, and tried to hold 2nd gear (2nd ends around 62ish) Right as I was about to shift into 3rd, it felt like I had put the brakes on hard, and my RPMs shot down, oil light and check engine light turn on. I thought that I'd spun a bearing (oil starvation is comman through long sweapers) I shut my car off and put it to the side of the track. Track puts the yellow flag out for me. One of the flag guy comes up to me, and asks me what happen, I respond, I think I blew my engine So he asks if I needed to be towed out. I said I wasn't sure, and said I would try and start it. Turn it on, starts up fine, no CELS, no oil light. So the corner worker says to try and drive it back in slowly.
I made my way around, went into the pits, and checked my oil, says about a qt low. At the begging of the session, I was a half qt OVER. As for the code, it ends up being 22. Vtec pressure switch, which makes sence. Low oil, plus all the oil flowing to one side of the pan during a long sweaper, would defently cause the presure to fall into dangerous levels. Also, this code cause you to go into limp mode, which expalins why my Revs suddenly dropped to around 4-5kish range. So I check to see where it was comming from. All under my car was soaked in oil. The spray had reached all the way to my GAS TANK. After inspecting where this was actaully coming from, the only thing we could see was a slow drip coming fromt the rear of the oil pan. Just last week I replaced this gasket when I put my baffled oil pan on (helps prevent oil starvation by stoping the oil from flowing up the sides. Best guess is, the gasket didn't seat that well, and the extreme torture of a roadcourse cause it to spring a leak at that point. It had been eating oil the entire day, but for a semi older engine, it wasn't too out of the norm. However, what we were thinking, since the leak was so small, I probally was suffering from this the entire day, but since I had been pushing it more that session, that was probally why it happen then.
Since the small leak wasn't dripping at that alarming of a rate, plus I had alot of spare oil, I decided to try and make it to the parts store, which was 5 miles away, and pick up a case of oil. By the time I got there, the level didn't drop off too much. I decided to just drive home, and just check and fill it every 30-40 miles or so. After about 5 or so stops, and 3 or so qrts of oil, I finally made it home. Sometime this week, I will just end up replacing the gasket, and hopefully that will solve it (99% sure it will)
