Stumped
Discussion in 'ECU's, Electronics, and Tuning' started by redhatch92, Feb 11, 2003.
  1. redhatch92
    redhatch92 Member
    New Jersey
    I have a 92 CX Hatchbak that I know is OBD1. I'm putting a 95 Ls non-Vetc that I know is also OBD1. My qustion is if I use a stock Ls ECM will everything plug right in or will I have to run any wires into the ECM and if so what wires?
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Plugs right in.ECM?you mean ECU?
  3. redhatch92
    redhatch92 Member
    New Jersey
    so i wont have to run any wires? its basicly plug and play?
  4. D See 2
    D See 2 Senior Member
    Baltimore, MD
    Electronic Control Module = Electronic Control Unit
    they are the same.
  5. xj0hnx
    C.C.TX.
    Got ya :D module,unit I get it.
  6. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    it'll plug right in yO. as long as they are both obd1 and you may need to use the LS wire harness
  7. redhatch92
    redhatch92 Member
    New Jersey
    Do you mean the engine wireharness or the ECM wireharness?
