My planned setup... Misc 1" Master Cylinder and booster from a 95 Integra w/ABS Russell SS Braided lines w/rubber coating DOT4 or higher fluid Front 94-95 Legend GS Dual Piston Calipers FastBrakes 11.2" "ITR" Rotor* Rear 02-04 Civic Si Calipers 02-04 Civic Si Rear Rotor *Reason I plan on using the FastBrakes rotor is simple. I will not have to have new lug holes drilled, as they come only in 4x100. Makes things easier. The car will mostly be used for spirited driving as well as track usage, once I get the transmission issues worked out. So please, suggest a good pad you think would suit my needs. Something along the lines of HAWK HPS's, however I want something with very little dust. And Yes, I will need tire suggestions... but that will come later, in a different thread!!!
