REDMAC
Trick or treat
Here's the problem. Whenever I take off the Tranny makes this metallic wining/grinding noise (actually it sounds more like a large electric motor winding up in a way). It has done this for the last 2 months I've owned it.
The other day I was pulling out the drive and it made a loud noise like a bearing going out or the the clutch slipped for a second. Today on the way to work I get off the gas and while its slowing down it kicks itsself out of 2nd gear and I can feal the shifter moving back and forth (feels like I can feel the engine moving back/forth thru the shift linkage) and its making the winding noise while drivng in lower gears.
Any suggestions on my problem. I can't afford to have this car go down right now and can't afford to change mult parts until I(with my limited knowledge) figure out whats wrong its X-mas time and have 2 kids.
