Suggestion on Cams for my 92-92 H22
Discussion in 'Engine Building' started by VenomPowered, Dec 12, 2003.
  1. VenomPowered
    VenomPowered Junior Member
    Utah
    I looking to get Skunk2 cams for my H22 engine. I know if I up the stage of cam i have to also modify my valvetrain. What mods do I have to do and does anyone recommand a differant Cam? <_<
  2. VenomPowered
    Utah
    Correction 92-94 sorry
  3. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    i think you answered your own question.
  4. VenomPowered
    Utah
    So you suggest Skunk2 also then
  5. swanny
    i havent heard any complaints on skunk2 and if the original question you were trying to ask is if you should upgrade your valves, springs, retainers etc with new cams with higher lift and duration the answer is yes.
  6. knowledge
    knowledge Senior Member
    Beale AFB, CA
    You can run Skunk2 stage1's without any other mods. But with Skunk2 stage2's you have better upgrade your valvetrain.
  7. Knives
    Knives Member
    the skunk2 cams stage 3 kit is coming out soon...so far they only have the stage one and two. If you have the cash go for the H22JUN cam kit. Its around 1500 dollars and comes with the cams valvesprings and retainers.
