Suggestion on Upgrade High-Cam
Hi
Suggestion on Upgrade High-Cam for original B16A BIG VTEC DOHC .
 Honda Civic JDM 92-95 B16A2 SiR II VTEC dohc .
 ECU P30-37820-000
 Manual Transmission c/w LSD g/b .
Need help on this problem . If I want to upgrade high cam from original B16A head high cam what I need to change / buy ?
Isnt I need to change/buy : -
- retainer cap
- valve
- spring
- ……anything else ?
thanks.
hes talking about the valve covers...the sir Vtec valve cover says "DOHC vtec"...from 88-91..then the 92-95 valve cover says "dohc VTEC"...hes trying to explain to yall that he has the second gen b16
if you want to go stock/OEM:
b16a
GSR/b18c1
ITR/b18c5
CTR/b16b
from low to high un terms of their bigness.
if you want to go aftermarket, theres 100's of different brands.
anything over ITR cams, i would recommend inner/outer valve springs and retainers.
[post=433068]Quoted post[/post]​
Thanks CRXSI91, thats what i am trying to tell you all . Dun screw me up guys .
cause i am new comer here , to learn english .
